Reboring 4agze
Reboring 4agze
Postby dohca » Fri Nov 02, 2007 5:38 pm
Hey has anyone had any experence overboring a 4agze 1.0tho?
just wondering if theres gunna be any problems ill face? ie head gasket etc obviously im going to need pistons and rings.
chur
dannyp
dohca
Postby Mr Revhead » Fri Nov 02, 2007 7:53 pm
ok..... do you mean 1mm? 0.1 thou? 0.01thou?
Postby dohca » Fri Nov 02, 2007 9:19 pm
1.0mm sorry i was half asleep when i wrote that lol i emailed you today about those pistons etc.. i spoke to the engine rebuilders today apprently they need to overbore by around 1.0mm so im not entirely sure which pistons i need i spoke to vvega today and he belives that 0.50" is the correct size i would require? could someone shed some light on this as im getting confused
dannyp
dohca
Postby dohca » Fri Nov 02, 2007 9:23 pm
also i can get a good silvertop block so maybe id be better using that and honing it to suit new standard pistons with rings rather than buying a whole new set of oversized pistons?
dannyp
dohca
Postby matt dunn » Fri Nov 02, 2007 9:56 pm
I have had a couple of engine bored by 0.5 and it's not a problem.
I think 1.0 is also available but never seen it done.
IMO if there are marks in the bores that require 1.0 to get rid of them,
go for another block.
Postby dohca » Fri Nov 02, 2007 11:27 pm
thats what i cant understand there are no visible marks on the block that would require that kind of machining to me it looked like a quick hone maybe a .5 overbore would be fine prehaps its out of round or something im not to sure i wasent there when they were measuring it up etc
ive sourced another block so i might just run with that insted
dannyp
dohca
Postby bluemaumau » Sat Nov 03, 2007 8:55 am
matt dunn wrote:I have had a couple of engine bored by 0.5 and it's not a problem.
agreed
i had a little play in my block so i got it bored out to .5 just to make it tighter than a nun.
its more the play in the middle of the bore that causes issues i think
