d1 mule wrote:my old 85 did that when i thought i was cool by taking the water pipes off the throttle body. not sure what thats called tho...
frost wrote:if its constantly high idle, like it stays at 2k then its the cold start air bypass valve under the throttle, i can show you how to recon it so you dont have to pay $180 for a new one if you like, its a bit tricky and you'll need a few tools but i can give a photo guide to how to,
This sounds useful, can you post it anyway? We probably need a faq on 16v idling problems with all the standard causes listed in order of probability with associated fix.
