20v + mitsi wasted spark what leads?
Postby AceSniper » Tue Nov 06, 2007 4:03 pm
What HT leads are best suited/fitting when using mitsi coils on a 20v,
and a rough length of how far away can the coils can be mounted
Ones I was using worked ok but real pain to get on/off the plugs and now there leaking spark
AceSniper
Postby AceSniper » Tue Nov 06, 2007 6:09 pm
Any idea if sumthen like this would fit/work...
http://www.trademe.co.nz/Trade-Me-Motor ... 534460.htm
or 16v 4age ones?
AceSniper
Postby postfach » Tue Nov 06, 2007 6:25 pm
you could always go into BNT or something, they sell 8 and 10mm HT leads in varying lengths, could probably find something to suit what you're doing.
postfach
leads
Postby fxgt race » Tue Nov 06, 2007 6:27 pm
we are using mitsi coils on the ae86 with a crank angle sensor setup,we are using trd leads,the top of the mitsi coils need to be trimed down a little,if you look in members projects at 20mm spanners project car this is the one we are building and there is a picture of the engine in this.Our coils are mounted on the rear of the cam covers.
fxgt race
Postby AceSniper » Tue Nov 06, 2007 6:46 pm
I have some 8mm lead here (made last lot) but I couldnt find anything suitable to secure and reach down the plug tubes.
fxgt_race any idea if the 16v leads fit down and clip onto 20v plugs?
AceSniper
leads
Postby fxgt race » Tue Nov 06, 2007 7:29 pm
the rubber boot on the end that connects to the spark plug is to big to fit down the 20v tube and knowing that yours have been squashed a little it makes it even smaller,in saying that you can change the boots on the end over by gently taking them off as they will fit,then a little bit needs to be trimed of the top rubber boot,no bigge and they will work,that is as a last resort so other leads that simply go right down the tubes are the easier option.
I was looking at the ngk leads on trade me and they look like they will work but you would need to try them,I was using ngk ones for a blue top to work out if they would work on the silvertop.
fxgt race
Postby AceSniper » Tue Nov 06, 2007 8:12 pm
thx for that, mite grab a 20v lead and bring it in have alook at afew kits, the honda one looks possable but would need them side by side
AceSniper
Postby matt dunn » Tue Nov 06, 2007 10:56 pm
I modify the standard 20V leads to suit the Mitsi coils, as we have the HT terminals and crimping gear at work,
only downside is that you are quite restricted on length.
Matt
Postby KinLoud » Wed Nov 07, 2007 7:18 am
Adrian - go see Autotrail? in Hamilton on corner of Lake Rd and Empire in Frankton, they make up leads. Visited them for my 3sge into my Carina.
Ken
Ham
021 408 863
Postby AceSniper » Wed Nov 07, 2007 1:33 pm
got some b20A honda ones Bosch inductive core, they all are the right length for my mounting and the tubes are 100% same length as stock 20v, might just have to cut I little sleve thats under the boot, I think they are a good fit for $80 but ill go try them first
AceSniper
Postby matt dunn » Wed Nov 07, 2007 9:55 pm
Has anyone else seen or experimented with the 4 coil pack setup's?
Apparantly I read on the net somewhere, :roll:
that you can use the 4 coils off a 1NZFE or 1AZFE or something?
