escortman wrote:iv heard that links are rubbish when its comes to controlling boost better to get a gizzmo ibc or something along those lines
Crampy wrote:The link computer has a closed loop boost control function. I have heard that they aren't as good as other EBCs, but if you've already got the computer, you only need the solenoid. You'll be paying someone to tune it, so while getting it tuned, get the boost control function setup.
Crampy wrote:You could go for an external wastegate, with a ~12psi spring and use a boost controller to increase it to 18psi when you require it.
Crampy wrote:You haven't said what turbo you are using though, so things can change things. You need to make sure you're turbo is still efficient at those increased boost levels.
l1ttle_d3vil wrote:
can any EBC'ers be set up for different boost settings, or are there only particular models available? and how easy is it to setup different settings like True-No-Turbo has? is it just a matter of getting the correct EBC and getting the different settings tuned correctly?
flygt4 wrote:i think its usually by a manual rocker switch etc to change the settings. you don't get a pretty display
l1ttle_d3vil wrote:and what about BOV's? its not such a crucial part of the setup (as in it won't blow up an engine), but don't want one that will leak or anything.
