old rwd offsets
old rwd offsets
Postby deaf_rattle » Mon Nov 26, 2007 6:26 pm
I am trying to sort out the correct offset for my celica supra. (MA61)
it currently has 15x6" wheels with an offset of +20 with 215/6-/15 g3s
I am hoping to run these tyres for now on some new 15" wheels, but i need to work out the correct offset for my car. (will get a better tyre choice later on)
Im wanting to go 15x7fr and 15x8rr, dont think id get 9s at the back.
Has anyone had any experience with their old rwd toyotas?
Postby drftnmaz » Tue Nov 27, 2007 10:03 am
i normally just work out from the rims you aready have...
ie if you get 15x8's the there 2" ~50mm wider so i'd start with the same offset and say 25mm wider each side.... then look at rim to strut clearance and see theres only 30mm and you want to keep 20mm clearance so then your change the offset to +10 to move the rim out 10mm...
then you end up with a 2" wider rim that sits out by 35mm
but if i was gonna run 215's all round i'd be running 9" wide rims, there only 228mm wide anyway
hope that helps
drftnmaz
Postby johntramp » Tue Nov 27, 2007 11:44 am
johntramp
Postby frost » Tue Nov 27, 2007 7:57 pm
man thats a good tool, good stuff john,
Postby deaf_rattle » Tue Nov 27, 2007 8:42 pm
yeah i know about that, but This calculator is for information purposes only and we do not guarantee fitment based on this calculator alone.
Postby johntramp » Tue Nov 27, 2007 10:51 pm
deaf_rattle wrote:yeah i know about that, but This calculator is for information purposes only and we do not guarantee fitment based on this calculator alone.
oh... sorry? :?
johntramp
Postby Mr Revhead » Wed Nov 28, 2007 8:24 am
good link johntramp, have added it to the FAQ section :D
deaf, thats an american site.... so overprotective disclaimer!!
what they mean is you also have to think about where the wheel will sit in reguard to the guard and strut etc.... and to double check before spending thousands on new wheels!
i dont think you will find anything more useful than that!
Postby spencer » Wed Nov 28, 2007 6:29 pm
ok my z10 soarer has 15*8's all around with 0 offest with no rubbing issues and its lowered, only on 195/55's though. These have the same suspension setup and similar guard clearance to the celica. Theres still miles on the inside on the rear with the correct offset (say +30) you could mash a 10" in there easy currently theres about 10mm to the guard in the rear which will be taken up when I adjust out the rear camber. basically your goal of 7's and 8's is piss easy aslong as you dont go into -ve offset crazy rims
edit: thats it there on the 8's
ms63 crown
spencer
Postby deaf_rattle » Wed Nov 28, 2007 7:59 pm
nice one dude, exactly what i was after.
anymore pics?
hmm maybe i should go for 9s in the rear :twisted:
