Ok so im just about to go get a wof and i was driving along and my speedo stopped working.. so i took the gaguge cluster out to check whether the cable is turning.. and as far as i can see it is not. and the cable hasnt come out of the gearbox.. is there something in the gearbox that might have fallen out of place?...
the speedo drive that comes out of the gearbox does not turn..
I took my speedo drive out last night.. and everything is defiantly workin.. but the worm gear and the gear on the speedo drive is not touching…. So thinking that it must be hardout worn… cause the worm gear is steel and the speedo drive is nylon… but they look ok.. any ideas?
