Rack And Pinion Conversion......
Postby 3T-Rona » Fri Nov 30, 2007 6:45 pm
anyone converted a KE2# to rack and pinion before?
Ive been looking for a KE7# setup but cant seem to find anything has anyone used anything else?
3T-Rona
Postby Mr Revhead » Fri Nov 30, 2007 7:15 pm
ke70 would be a bit wide i think
maybe kp60?
Postby 3T-Rona » Sat Dec 01, 2007 8:51 am
maybe i have to make a mutant b@stard setup with mounts welded to my xmember and so on, Im no steering an suspension expert how do u go abou measuring the steering arm width etc, maybe i should measure the original width (which ive already removed so if any KE2# owners want to measure theres for me it would be super) and cut and bodgey the steering arms to the right length, cnt be that hard can it
3T-Rona
Postby Mr Revhead » Sat Dec 01, 2007 9:07 am
you will have to make mounts
if a KP rack is suitable cut them off a KP crossmember
you will need to finds steering arms that match the bolt pattern of your struts. unless the ke20 ones suit a KP type tie rod end.
with toyotas theres only a couple of b/j and tie rod b/j types.
so mixing and matching to get the right combo isnt too hard.
see f you can scrounge a KP rack to play with. having it there to look at will help a lot!
what are you doing about struts?
Postby 3T-Rona » Sat Dec 01, 2007 6:50 pm
I dont know yet its hard to think about without knwing about the options, i have a set of skyline (the turbo ones) calipers to use, its not gonna be doing any serious turning action (straight line mostly) so steering doesnt matter to much (need rack&P for engine bay space)
any advice on strut-bottom arm combination?
3T-Rona
Postby ezy10s » Sat Dec 01, 2007 6:55 pm
if possible id be trying to use the all the steering/suspension components from a kp starlet- at least that way your geometry/ ackerman will be right. even if its a bit of a faff around to make it bolt to the ke chassis rails.
Member #244
Gone fishing until further notice
ezy10s
Postby terola » Sat Dec 01, 2007 9:00 pm
viewtopic.php?t=15806&highlight=rack+pinion
I had a setup in a ke just tacked in but afterall decided not worth it just for the hassle of the getting the angles right etcetc
terola
