2t and 18r diferances
Postby 79rolla » Sun Dec 02, 2007 1:41 pm
hey i got a 2tgeu and have opitunity to buy a 18rgeu
i know ecu and inlet manifold are interchangeabil and the head has the same studs ect but what other simeraritys are there??
i know 18r's normaly have w55 behind them but would a t50 work if i used a t series bell housing??? are the gngine mounts the same on them???
thanks heaps if anyone can tell me anything
past: AE82 FXGT
79rolla
Postby thegreatestben » Sun Dec 02, 2007 8:11 pm
18r's have W50 behind them.
Can't tell you much else.
thegreatestben
Postby 79rolla » Sun Dec 02, 2007 8:28 pm
do you know how diferent the bell housing is? how hard would it be to adjust a t series bell housing to fit????
past: AE82 FXGT
79rolla
Postby sleeektoy » Mon Dec 03, 2007 4:26 pm
79rolla wrote:do you know how diferent the bell housing is? how hard would it be to adjust a t series bell housing to fit????
Nearly impossible to mod one and there are some celica/coronas out there with the standard 18R engines with T40/50's behind them so looking hard at some oldschool wreckers might yield one.
2T-G engines were based on a single cam pushrod engine
18R-G engines were based on an SOHC engine
Heads are totally different - only a few parts are interchangable
the upper 1/2 of the EFI inlet is the same on both with the throttle slightly bigger on the 18R-G
toymods has a good forum on these engines
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby 79rolla » Mon Dec 03, 2007 8:08 pm
yeah thanks... not going to get it as the engine mounts are diferent and bell housing is also so no point as it would have been a spere for the 2t
past: AE82 FXGT
79rolla
