CANT START MY 4AGTE
CANT START MY 4AGTE
Postby tsoob » Mon Dec 03, 2007 9:15 pm
Can anyone help me? i was talking to mechanic who was going to come help me to start my car, but he didn't show up. I need the help of someone who has a timing light and a fuel pressure gauge with a little experiacne in starting a fresh engine. I can provide beer/weed or what ever in return for the favour, im really pressed for time as i dont have my company car any more and have had no joy from my non mechanic mates, would really appreciate it pm if you can help.
A huge thankyou to toyspeed
Nick
tsoob
Postby 79rolla » Mon Dec 03, 2007 9:28 pm
quick question...
where are you?
past: AE82 FXGT
79rolla
Postby tsoob » Mon Dec 03, 2007 10:35 pm
great question sorry north shore auckland
Nick
tsoob
Postby tsoob » Tue Dec 04, 2007 6:04 pm
can anyone help? please
tsoob
Postby AE86less » Tue Dec 04, 2007 6:09 pm
Can't help with the car, but am willing to be supplied with w33d. It's a hard job but someone needs to do it.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby themaleman » Tue Dec 04, 2007 6:13 pm
me too :D
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby tsoob » Tue Dec 04, 2007 6:13 pm
AE86less wrote:Can't help with the car, but am willing to be supplied with w33d. It's a hard job but someone needs to do it.
If you can bring a mechanic with you will happily blow you out tooo!!!!
tsoob
Postby bluemaumau » Tue Dec 04, 2007 9:14 pm
so its not even cranking?
Postby tsoob » Wed Dec 05, 2007 11:21 am
cranks over got spark and the injectors are firing but dont know if any fuel is going in, im sure the timing is right, but would like to check again hence the request for a timing light. The fuel is hooked up but dont know if the pressure is there the fuel pump is going?? any ideas?>
tsoob
Postby Stu- » Wed Dec 05, 2007 11:38 am
Stock ecu?
Project Thread
Stu-
Postby 79rolla » Wed Dec 05, 2007 11:48 am
is it getting fule? you might need to presurise the tank and see what happens wen you tern it over (need air compressor for this)
past: AE82 FXGT
79rolla
Postby MacrosSiR » Wed Dec 05, 2007 5:48 pm
are the spark plugs wet?
MacrosSiR
Postby tsoob » Wed Dec 05, 2007 6:25 pm
no microtech ecu all wiring has been triple checked, not too sure about the plugs will check them now.,
tsoob
Postby postfach » Wed Dec 05, 2007 6:30 pm
tsoob wrote:The fuel is hooked up but dont know if the pressure is there the fuel pump is going?? any ideas?>
disconnect the return, either after the regulator or at the tank end, turn the key and see if fuel comes out
postfach
Postby flygt4 » Wed Dec 05, 2007 6:46 pm
or fill the intake with engine start, it will fire and run on it alone for a few seconds. will confirm that timing and spark is correct. just keep a fire extinguisher handy.
i had a problem with flat fuel which stopped my engine starting after a long hibernation.
flygt4
Postby tsoob » Wed Dec 05, 2007 6:47 pm
flygt4 wrote:or fill the intake with engine start, it will fire and run on it alone for a few seconds. will confirm that timing and spark is correct. just keep a fire extinguisher handy.
sounds a little hairy but will try anyting atm
tsoob
Postby postfach » Wed Dec 05, 2007 7:14 pm
I'd take a stab in the dark and assume he doesn't literally mean fill it, either :wink:
Check there's actually fuel flowing through the system before you do that, though.
postfach
Postby Mike- » Wed Dec 05, 2007 8:25 pm
low/high impedance injectors?
Mike-
Postby flygt4 » Wed Dec 05, 2007 9:06 pm
postfach wrote:I'd take a stab in the dark and assume he doesn't literally mean fill it, either :wink:
haha yes not literally. a few seconds spraying will do it.
be careul as its damn explosive and if you have any pool at the bottom of the intake and your timing is out, it will blow it back out the intake in a fireball. trust me, dry powder is a bitch to get out of an engine bay :lol:
flygt4
Postby tsoob » Thu Dec 06, 2007 10:56 am
update, there is definitly fuel fuel coming out after the regulator, so not sure, i am running resistors to the injectors, so they are low impednce you can hear that they are firing, i am starting to think it is a wiring problem have been on the microtech forums and web sites and have found a few people have had issues wehre the loom from the factory wasn't wired up correctly so we are having to redo the cas, does any one have a wiring diagram to suite a ae92 afm version of the 4agze with the wire colours for the cas? other than that it should go also if anyone has a wiring diagram for a tps off a bigport 4age (blue top) atm the thig is wired to be switching type not a variable so it senses that it is on.
Nick
tsoob
