"My name is Dennis and I am an administrator with the Corrado Club of Canada and I have question about rim sizes & allowable tire widths. I have seen many people fitting tires that are below the minimum recommended rim width being mounted on wider rims to have a stretched look to them. This is results in a narrow tire on a wide rim and from working in the automotive industry for years I know this is not a safe practice. Most of these people are doing this strictly for looks and are unaware of any dangers involved. I was hoping your association would comment on this and say why this is unsafe or safe for that matter as tire shops do mount these combinations. I would be interested to hear how this changes the handling of the tire and what safety concerns a person with this set-up may have such as excessive heat build up or de-rimming tires. I believe this to be a safety concern but it is hard to find any information about this. I have tried many tire manufactures with this same concern and none of them wish to comment. I am concerned because many people do not know there is any issues with this combination and do so simply because they have seen others do it. Any help would be greatly appreciated.
Here's the respose from the Rubber Association of Canada...
quote:
Hello Dennis,
Your concern regarding motorists who stretch tires onto wider than
acceptable rims is certainly justified. The tire industry and wheel
manufacturers do have a joint organization called the Tire and Rim
Association, based in Akron Ohio which does set standards for acceptable
tire/wheel combinations. And though it would surprise me if reputable tire
retailers would knowingly put a smaller tire on a wider than acceptable rim,
I suspect it does happen.
The obvious danger is that the bead will not/cannot "seat" properly, thereby
potentially destroying the tire bead and causing tire failure, either during
installation or aggressive driving. In either case, the damage could result
in serious or even fatal consequences.
You may want to consult with TRA for more specific information.
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
79rolla wrote:but hey if you wanna look [person of homosexual orientation] and fall off the road feel free... just dont be around me wen you do it
Snoozin wrote:I'd have a stretched tyre over a ballooning tyre any day... although a set of 13x5.5 Cheviot Turbo's running 215/60's is sooooo appealing.
drftnmaz wrote:its done to reduce sidewall flex to aid handling, and to get more traction.... most people think wider tyre= more contact to the road then think more traction BUT when you think about it its the pressure the tyre is excerting on the road so espally in light cars bigger tyre= less pressure spread across the contact patch and less traction... it comes even more into play in the wet.
but most people just do it for the drifter look auuu
and frost post up those pics or pm them to me... Chur
Yoko A539's are a good bet as far as sidewall goes...
Snoozin wrote:Some awesome stretch, best I could find at short notice.
Snoozin wrote:Practice > theory.
Never seen a drifter have any troubles with them, and they run some fairly excessive stretch and one would think some pretty extreme lateral loads on their sidewalls.
Adydas wrote:biog room to argue tho...
"are an appropriate selection for rim width, and"
