AE101 Levin GTZ Dash
Postby big-ben-007 » Thu Dec 06, 2007 12:11 pm
Over the past couple of months I have been having problems with my dash, basiclly it seems that speedo is tying to get a speed reading however it keeps dropping off, and its making a flicking kind of action and never holding a constant speed, thus not warentable, which is handy because it is due today :lol:
Thinking it was the dash itself I brought a second hand one off trade-me basiclly just to check if it was the dash itself with the problem, after a quick drive around the block it was apparant it's not the dash.
This keeping in mind I have checked for all the other connections it could possibly be.
So I am left with the possiblilty going through the loom and trying to find a half broken wire...............
So just before I embark on this wonderful mission of mine has anyone got any idea on what else this could be??
ant help would be greatly apreciated :D
Now: 1956 Dodge Pick-up, 1988 EP71 Starlet
Before: 1985 Ford Telstar, 1989 Mazda 323, 1991 Ford Telstar s/w, 1991 Nissan Pulsar GTI, 1991 R32 Nissan Skyline RB20DE, 1991 AE101 Levin GTZ Superstrut Version
"Oh man, I just shot Marvin in the face" - Vincent Vega
big-ben-007
Postby Distrb » Thu Dec 06, 2007 12:31 pm
could be that the speed sensor in the gearbox is tired/worn out, or not plugged in properly
check that before you start looking for broken wires
Distrb
Regular Poster
Postby AE82 FXGT » Thu Dec 06, 2007 8:58 pm
Yes I've found 80% of the time a problem like that will be a sensor or plug or something like that not often it's a broken wire.
Unless someones been doing any wiring or if the wires go across a hinge like a door or boot with constant flexing. But it's usually something easier.
AE82 FXGT
Postby Boosted_162 » Thu Dec 06, 2007 9:05 pm
A mate had that problem in his ST185, ended up being electronic speedo sender (the rest of the dash was fine). Got it replaced by Toyota ($$$$), but Warwick could give a better price.
Postby flygt4 » Fri Dec 07, 2007 7:53 am
there are 2 types, mechanical and elctronic. it easy to check which you have as it will either have a plug or a cable. i think ae101 are electronic?
i have a mechanical one sitting on my shelf if you need it.
flygt4
Postby big-ben-007 » Fri Dec 07, 2007 11:10 am
flygt4 wrote:there are 2 types, mechanical and elctronic. it easy to check which you have as it will either have a plug or a cable. i think ae101 are electronic?
Yep it is electronic, the plug is in perfectly, but I never really checked the condition of the plug itself before, so that will be something to do after my CBF Syndrome passes
big-ben-007
Postby big-ben-007 » Mon Dec 17, 2007 12:56 pm
Also just a quick question so I make sure I havnt been looking in the wrong place,
but which plug is the one that reads the speed from the gerabox ie: where is the plug located on the g-box??
Any answer is very much appreciated
big-ben-007
