CaldinaGt_t wrote:any body has done any extreme modifications to these engine and have info on mods that can be done both N/A or Forced Induction?
trust me it is, its make good early power right up to redline, boost never falls off. its just Great!Lith wrote:CaldinaGt_t wrote:any body has done any extreme modifications to these engine and have info on mods that can be done both N/A or Forced Induction?
Not yet in NZ that I know of, though you never know - there are some random crazies up to stuff in sheds here.
How is the TD05-Big 16G on a 3SGTE? I've often thought that could make a neat combination.
Mr Revhead wrote:still a little new for NZ to have done much with them!
call TRD race engine division!
Mr Revhead wrote:they are in the Aurion
hell, someones fast off the bat!
fangsport wrote:are these the alloy V6 camry engine?
if they are, i heard the speedway guys are playing with them, and getting better responses than the 1uz
but the 1GR-FE rods are weak.strx7 wrote:the 2GR-FE in the current camry's etc pump out a hefty 207Kw and 350odd Nm. if you were able to combine the added stroke of the 1GRFE with the higher compression, cams etc etc from the 2GRFE you should be able to extract somewhere near 220KW from it
CaldinaGt_t wrote: but the 1GR-FE rods are weak.
strx7 wrote:CaldinaGt_t wrote: but the 1GR-FE rods are weak.
Change them to aftermarket items, just use the 1GRFE crank, not that hard really.
this is a run down on these engines
1GR-FE 3956cc (new hilux engine)
94mm bore 95mm stroke
175kw @ 5200 376Nm@ 4800rpm
2GR-FE 3456cc (new camry sportivo, estima etc etc)
94mm Bore, 83mm stroke
204kw @ 6200rpm 346Nm @ 4700rpm
2GR-FSE 3456cc (Lexus IS350)
232kw @ 6400rpm 377Nm @ 4800
3GR-FE 2994cc (lexus IS300)
87.5mm Bore, 83mm Stroke
170kw @ 6400rpm 300Nm @ 4800
3GR-FSE (crown) 188kW @ 6200 rpm 314Nm @ 3600 rpm.
4GR-FE 2499cc (lexus IS250)
83.1mm Bore 76.9mm stroke
152kw @ 6400rpm 265Nm @ 4800rpm
CaldinaGt_t wrote:
thats what im asking about where to get performance parts for these engines
