1GR-FE mods
Postby CaldinaGt_t » Thu Dec 13, 2007 3:13 pm
strx7 wrote:
CaldinaGt_t wrote:
thats what im asking about where to get performance parts for these engines
You or someone you pay, fabricates them to suit.
After market ecu, higher compression pistons, custom rods, 6 throttle bodies, custom manifold and 6 ram tubes. headers, good exhuast, slightly more duration cams with more lift, custom valve springs, how hard core do you want to go?
thats gonna cost alot!
3SGTE POWER RULES!
2000 Caldina GT-T
TD05-BIG16g,o2 housing wid external dump pipe, front mount intercooler, speed limiter removed, 1jz-gtte pistons, and lots of boost
CaldinaGt_t
Postby strx7 » Thu Dec 13, 2007 9:44 pm
if YOU are PAYING someone else to do it for sure
Postby CaldinaGt_t » Mon Dec 17, 2007 2:26 am
strx7 wrote:if YOU are PAYING someone else to do it for sure
well ill be paying for it, so its gonna cost alot.
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby RedMist » Mon Dec 17, 2007 7:06 am
You could cheat, just a little, and go Nissan. The VQ35DE is placed in everything from Maxima to Terrano. The engine I have is from a 350z and the only thing that differs from other VQ's is the intake manifold. Cheap as chips and a tonne of off the shelf aftermarket gear for them. Including turbo and superchargers, pistons, cams, headers, etc.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby CaldinaGt_t » Tue Dec 18, 2007 4:50 pm
RedMist wrote:You could cheat, just a little, and go Nissan. The VQ35DE is placed in everything from Maxima to Terrano. The engine I have is from a 350z and the only thing that differs from other VQ's is the intake manifold. Cheap as chips and a tonne of off the shelf aftermarket gear for them. Including turbo and superchargers, pistons, cams, headers, etc.
if i wanted i could just go the 2GR- which is the same spec.
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
3SGTE POWER RULES!
2000 Caldina GT-T
CaldinaGt_t
Postby darkwolf » Tue Dec 18, 2007 6:03 pm
And has dual vvt-i :twisted:
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
