can you not just pull the rail and injectors out as a unit, and crank to see if you have fuel at the pintles?
if you have press to the rail and can hear the injectors pulsing it should have fuel @ the head.
tsoob wrote:yes i can do that but think the problem is more to do with the cas now.
tsoob wrote:ITS ALIVE
we finally started it today have heaps of work to do on it yet but its a go-er at least i want to take it away for new years so ill be in the shed for the next few days.
