Confirmation: ZE Pistons okay in 20v head?
Postby Zyros » Thu Dec 20, 2007 10:40 pm
Just confirming, although my engine is built (mostly)
Are, 4agze 16v pistons okay to use in a 20v 4age silvertop head.
Just was thinking how the pistons have the four dishes on the top for the valves on the head, yet a 20v has 5 valves per bore...
Just making sure incase the piston does rise high enough to hit a valve?
Zyros
Postby Mr Revhead » Thu Dec 20, 2007 11:10 pm
yes fine
jsut becomes an interference engine
Postby Zyros » Thu Dec 20, 2007 11:43 pm
Mr Revhead wrote:jsut becomes an interference engine
What do you mean?
Zyros
Postby sergei » Thu Dec 20, 2007 11:46 pm
it means if cam belt breaks then the valves touch the piston.
Most of the other make engines are interference .
Postby thegreatestben » Thu Dec 20, 2007 11:47 pm
If the cambelt snaps or whatever the pistons will smash into valves.
beaten to it.
I think smash is better for dramatic effect though
thegreatestben
Postby d1 mule » Fri Dec 21, 2007 2:41 am
im pretty sure im 99% wrong seeing as revhead, sergei and tgb.mr2 have said i thought the early ZE pistons have a mega dish in them?
d1 mule
Postby Mr Revhead » Fri Dec 21, 2007 8:39 am
yeah big dish
i wasnt sure if they would contact or not
untill matt set me some pics of his experiments.
they do touch 8O
Postby d1 mule » Fri Dec 21, 2007 12:37 pm
hmm i would have thought the dish was bigger than the recess cut for the valves, oh well iv learnt something today then haha
d1 mule
Postby Mr Revhead » Fri Dec 21, 2007 12:52 pm
i think its to do with the positioning of the inlet valves rather than overall piston dish.
Postby d1 mule » Fri Dec 21, 2007 1:40 pm
ah that makes sense, so m ust hit on the outside lip bit thats not recessed?
d1 mule
Postby ChaosAD » Fri Dec 21, 2007 6:05 pm
Their was a thread not long ago about someone that sold a 20v with gze slugs and it skipped a tooth or something. That engine was definately an interferance one 8O
ChaosAD
Postby matt dunn » Fri Dec 21, 2007 10:57 pm
Ypu can quite clearly see here where 3 out of the 5 valves touch when the cambelt breaks,
And if it doesn't break but just slips a few teeth or so,
you end up with 12 out of 20 valves looking like this,
Matt
Postby Alex B » Fri Dec 21, 2007 11:25 pm
Yea, don't $&#$% up the timing :lol:
Postby Bling » Sat Dec 22, 2007 9:57 am
20v are interferance in some case anyway, for example, stuff up a gear shift and drop down a gear rather than go up a gear, cambelt slips, engine revs till it can rev no more, valves get bent.
still I guess if you are driving like a nana when the timing goes out you might be ok
Postby Mr Revhead » Sat Dec 22, 2007 12:24 pm
only in blacktop. silvertop is non interference
Postby Bling » Sat Dec 22, 2007 1:34 pm
why is it always the good one with the downside :( :lol:
Postby matt dunn » Sat Dec 22, 2007 2:01 pm
Mr Revhead wrote:only in blacktop. silvertop is non interference
But a BT would throw a rod first, lol.
Postby Bazda » Sun Dec 23, 2007 1:27 pm
The 20v blacktop head will only hit on the exhaust side using 8.0:1 gze pistons (dish ones), if you look at a BT piston there are no cutouts for the inlet side only the ex side.
The Siltertop head is a diff story as the head chamber is alot shallower so would prob hit as in matts pics.
