Mounting a fire extinguisher into a SW20
Postby Baxter » Sun Dec 30, 2007 12:09 am
Just bear in mind some scrutineers will not pass one mounted under the driver's seat (or indeed anywhere in the driver's footwell) because if the catch is accidentally flicked (eg overalls etc) the extinguisher could roll under the brake peddle.
Having said that afaik many people do run them there, so I assume you need to make sure the release catch is turned inwards and cannot be caught by anything, or vibrate loose.
Also the "when seated" is generally read as seated and belted, so options are very limited in MR2s.
I'd probably consider putting it on the passenger's side of the the "transmition" tunnel as close to the gear shifter as possible; if you can reach it there and if there's something to bolt it to behind all the plastic.
Baxter
Postby Leon » Sun Dec 30, 2007 3:36 am
Baxter wrote:Just bear in mind some scrutineers will not pass one mounted under the driver's seat (or indeed anywhere in the driver's footwell) because if the catch is accidentally flicked (eg overalls etc) the extinguisher could roll under the brake pedal
Reaching extinguisher while wearing belts.
While this risk is true, as it says nothing about this anywhere in the MotorSport Manual, they are not able to fail you for that. If you are not happy with a scrutineer verdict, simply request a decision from the Clerk of Course of the event. In this case, the Clerk of Course would rule in your favour as the scrutineer would be making up rules that don't exist.
The rule is deliberately written as when seated, not when seated and wearing harness, so again, that should not be an issue. You will find that it states you need to be able to reach your mandatory controls (ignition, wipers etc) while seated and wearing belts. So the seated only requirement for the fire extinguisher is clear cut.
Postby Leon » Sun Dec 30, 2007 3:40 am
AJz wrote:im with the infront/under your seat.
Think about it this way, your more than likely the only one to drive it right, how often are you going to move that seat ???
It should miss the extinguisher by miles. I've put extinguishers straight in front of the driver seat in about ten cars, and it hasn't got near in any of them.
Postby Heylin » Wed Jan 09, 2008 2:55 pm
I got the same extinguisher and have mine mounted under the front passenger seat.
Heylin
Heylin
Postby barryogen » Wed Jan 09, 2008 4:11 pm
Heylin wrote:I got the same extinguisher and have mine mounted under the front passenger seat.
as opposed to the back seat? :lol:
I'd think it would be hard to reach from the seated position... although you may not do racing, so might not be an issue, just a precaution.
barryogen
2ZZ Guru in training
Postby DeviousMR2 » Wed Jan 09, 2008 5:12 pm
iv got mine bolted to the floor in front of the passengers seat, doesnt affect seat operation at all and has passed scrutineering with no problems at all in that position, and yes i can reach it from my seat too
theres not many other places you could really put it in an mr2
1991 G LTD MR2 SW20 [DVSMR2]
firing on all 6 since easter 07 :D
http://www.halfassedmotorsport.co.nz
DeviousMR2
Users browsing this forum: Bing [Bot] and 17 guests
