Wiring a 93 Celica Stereo
Postby Capin-Neemo » Fri Dec 28, 2007 5:51 pm
Hi having a problem wiring a celica after market stereo its the model with the super surround system in it so the wiring is different from standard.
I don't want to remove the factory amp box just want to wire it up so anyone ever figure out the colours of the two plugs?
The original sterio was a doubble din with cd player so im a little confused here any help thanx.
Capin-Neemo
Postby AJz » Fri Dec 28, 2007 7:43 pm
Toyota's have 2 plugs. 4prong (red white yellow and back) is your rear, and bigger main one with blue/yellow (constant),grey (acc) and brown (earth). cant member the fronts colours etc.
PM DeeCee off these forums, he should be able to help. Or take a clear picture and post it up.
I had vtax :(
AJz
Yea! Hmm
Postby Capin-Neemo » Fri Dec 28, 2007 8:38 pm
I do realise this ill put up a pic the stock japer head unit is a doubble din head unit so the plugs are differnt as bellow and the wiring is differnt to i.e no grey!
Any help would be apecitated thanx.
Also just as a side note there is an amp under the passenger seat with 3 plugs in it.
Neemo out.
Capin-Neemo
Also found this
Postby Capin-Neemo » Sat Dec 29, 2007 7:23 am
See a full sized image here http://i9.photobucket.com/albums/a56/ca ... dailrg.jpg
Thats half of what i need ill do some reaserch when im back from holiday, yea the coromandel!
That diagram looks like the amp wiring so just have to figure out the dash end.
Capin-Neemo
Postby piw » Sat Dec 29, 2007 1:24 pm
The original stereo you are removing does not have an anp in it and will not drive speakers, it only puts out a very low level signal.
That also means the amp does not accept speaker level inputs,
so you cannot hook up a standard pioneer etc etc stereo to the existing amp.
Been there, tried that, doesn't work.
piw
Postby Mr.Phreak » Sat Dec 29, 2007 3:57 pm
You need one of these and a stereo with two sets of preouts
Mr.Phreak
Thanx
Postby Capin-Neemo » Tue Jan 01, 2008 6:59 pm
Duh now i rember that in the MR2 exactly the same must have had too much special tobacco lately lol.
Any whoi guess ill just have to re wire the hole car easy as that will be a day project instead of a few hour no biggy.
I'll up some pics for anyone that wants to try the same thing.
Capin-Neemo
