autogauge 2" smoke series wiring
Postby levinguy » Sat Jan 05, 2008 1:29 am
long story short got a couple of gauges, no wiring with them (water temp, oil pressure)
two sets of wires one short set, one long, have searched the net couldn't find anything, not even on the autogauge site.
short wires are::
black, orange, and red, - black has been earthed, and red to 12v, lites up the gague
long wires are:
black, red, and green
any ideas what the other wires go to? perhaps someone with the same gauges can check for me?
they are not the type that have different colours either
thanks!
levinguy
Postby evil_si » Sat Jan 05, 2008 9:21 am
did they come with the appropriate sender units? or have you just got the guages,
worthless if you have just brought the guages, generally tend to be stolen if thats the case.
different story thou if you ahve the sender units
evil_si
Postby Ae92typeX » Sat Jan 05, 2008 10:05 am
so to clarify, each gauge has 6 wires yes?
what evil_si says above also though
Ae92typeX
Postby levinguy » Sat Jan 05, 2008 10:45 am
yeah they have the senders, came boxed and everything, definatly not stolen, just missing the diagrams.
senders are both one wire electric ones
yeah 6 wires
levinguy
Postby gasman » Sat Jan 05, 2008 11:25 am
i think from memory of installing a few gauges in my brothers car the orange wire go to a light switch to either dim them or make them brighter at night time? just try it out. the long wires probably go to power earth and signal.
"What can possibly go wrong?"
gasman
Postby evil_si » Sat Jan 05, 2008 3:38 pm
check out autoguages website or try ringing pioneer autoparts in auckland for a diagram,
should be
switched + supply
constant + supply
earth
wire to sender unit
supply from light circuit
and possibly earth for light circuit
when it comes to hooking up the light wiring be careful. i know of a few people that have had a few troubles and killed a few things and lost all dash lights etc
evil_si
Postby gepsk8 » Sat Jan 05, 2008 6:13 pm
earth is black
red in postive,
orange feed will go orange
red feed will go red i think maybe white.
O272754663
gepsk8
Postby metric » Mon Jan 07, 2008 1:28 pm
red does the backlight
orange does the needle
metric
