how close is too close?
Postby l1ttle_d3vil » Sun Jan 06, 2008 5:49 pm
i'm no turbo expert so would prefer to confirm from other people before making assumptions based on my own inexperience :lol:
is this turbo going to be too close to the strut tower, heat-wise? six inch ruler is just there for reference...
there isn't enough flex in the mounts for it to torque over and hit the tower, so only worried about heat.
Postby tsoob » Sun Jan 06, 2008 5:58 pm
very close but i dont think it will harm the strut tower, not sure what will happen to the shocks tho..
tsoob
Postby Anth_555 » Sun Jan 06, 2008 6:22 pm
you could get one of thos beaney heat sheald things
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby evil_si » Sun Jan 06, 2008 6:51 pm
thats the cold side of the turbo, doesnt get hot in comparison to the exhaust housing,
dont worry bout using a turbo beanie etc on that side of it..
on another note it may be to close depending how much your engine moves / twists.. how good are your engine mounts??
evil_si
Postby flygt4 » Sun Jan 06, 2008 6:57 pm
my exhaust side is closer than that to the back of my radiator.
had issues for a while with the radiator flexing back into under load but solved by cabletieing the radiator in place. no further issues.
flygt4
Postby l1ttle_d3vil » Sun Jan 06, 2008 7:57 pm
evil_si wrote:on another note it may be to close depending how much your engine moves / twists.. how good are your engine mounts??
doesn't get near to touching the tower, only the heat I was worried about. could always invest in some stiffer rubbers though as the ones i've got are pretty soft.
thats heaps of room compared to my inlet side though, it rubs the brake master cylinder occasionally...not much room for movement either side. damn small engine bays!! :evil:
Postby evil_si » Sun Jan 06, 2008 8:02 pm
yea no heat to be worried about from that,
ha small engine bays. ke's have heaps of room :D
evil_si
Postby 3T-Rona » Mon Jan 07, 2008 7:13 am
arent you goin to run a link ECU? strip the cap and crapp off that dizzy and turn it into a cam/crnk angle sensor (remove a tooth from one of the wheels) and then you cld cut and reweld that turbo flange at a straighter angle. also a good place for tuning in TGA is Dynopower, good guys, good tuning, good price :D
3T-Rona
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
