Cam timing
Cam timing
Postby Dell'Orto » Tue Jan 08, 2008 12:23 am
Finally got around to dialling in my cam (4K, with adjustable cam gear).
As the cam gear doesn't have any markings as such, I've been fiddling back and forth til I basically got sick of doing so :lol:
I've got it pretty close, but is about 1º retarded from the recommended spec. Realistically, will it make a noticable difference? I know theoretically it'll lose a little low end and gain it up high, but is it worth pissing around with the camgear for another 1º or will it be fine as is?
Brad
Tweaks....
Postby jondee86 » Wed Jan 09, 2008 5:41 pm
One degree at the crank is hardly likely to make a difference. Thats
about the sort of difference you can expect from kryptonite tipped plugs,
an electric turbo, or those magnetic fuel conditioners.
So long as you reset your ignition timing after fiddling with the cam, you
should be good to go :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby ChaosAD » Thu Jan 10, 2008 1:01 am
Yea you'd probly get that much difference after planing a cyl head.
Maybe thats why it had more grunt :?
ChaosAD
Postby matt dunn » Thu Jan 10, 2008 3:20 am
I reckon the flex in the cam chain while running will give it more than 1 degree.
Postby Dell'Orto » Thu Jan 10, 2008 12:17 pm
Sweet, didn't think it would (also couldnt be arsed fiddling with the cam gear anymore :lol:).
