1J cam specs?
1J cam specs?
Postby d1 mule » Tue Jan 08, 2008 3:59 pm
im wondering if anyone knows or knows where to find the specs on 1JZ cams (lift, duration)
reason being iv got a 1JZGE and will be buying a GTE shortly, and am wondering if the NA cams have more lift/duration
my plan is to but a 1JZGTE and swap the turbo head onto the NA block (short term) and re build the bottom end as will be a dedicated drift/ odd track day car.
so on the note will a GTE loom plug into GE knock sensors, alternators etc??
oh car in question is a JZX81
d1 mule
Postby strx7 » Wed Jan 09, 2008 9:21 am
1JZGE cams have a dizzy drive on them and no lumps for Cam Angle Sensors
1JZGTE cams have no dizzy drive and have lumps for Cam Angle Sensor.
the only way its do-able is if you use the cams from a VVTi JZGE head as they run the same sensor trigger lumps at the JZGTE does.
also the JZGE heads have VERY different inlet and exhuast manifold FLANGE patterns ie - you cant swap them over, which pretty much puts a quash on your idea
Postby d1 mule » Wed Jan 09, 2008 9:25 am
well there ya go :D
thanks man lol
d1 mule
Postby strx7 » Wed Jan 09, 2008 11:42 am
this was covered approx 2 or 3 months ago in the tech forum
