Few questions
Few questions
Postby Emperor » Tue Jan 08, 2008 4:15 pm
First -
Who can pull apart alternators and get them chromed up / painted?
Are they easy to undo yourself and put back?
Just looking to clean up the engine in my seven, paint/chrome a few peices.
Second -
Who can do custom fuel lines for surge tanks? and is it better to buy two better pumps (one in tank, one after surge tank) or is the standard in tank one fine?
dont want the surge tank to run out before the stock pump can put more into it
Emperor
Postby Bling » Tue Jan 08, 2008 4:29 pm
first -
i've pulled a few alternators apart, albiet K series ones, they all look similar tho. But it was easy as, so easily a DIY thing imo
Postby Dell'Orto » Tue Jan 08, 2008 5:10 pm
Yeah alternators are piece of piss, I've had mine chromed, looks heaps better. Just take the cases to any electroplater and they'll sort it out.
Any performance type of workshop will be able to do new lines. I think most people use the stock pump as a lift pump for the surge tank.
Postby gepsk8 » Tue Jan 08, 2008 6:13 pm
not alway easy as bearing seize, break brushs,regulator, recifiers get broken.
i would get auto sparky to pull i apart, get chromed and then reassembly with bearings and brushs save time later in it not $&#$% out.
O272754663
gepsk8
Postby Dell'Orto » Tue Jan 08, 2008 6:18 pm
If you break a rectifier I'd suggest you missed a bolt someplace! 8O You'd have to be pretty rough to do that.
Postby gepsk8 » Tue Jan 08, 2008 6:32 pm
yea, but he wouldn't have ever pulled one apart im guessing, so ppl get ruffor using the wrong tools!
O272754663
gepsk8
Postby l1ttle_d3vil » Tue Jan 08, 2008 6:45 pm
start pulling it apart, if you're confused, put it back together exactly how you found it.
i'd never pulled one apart until the other day when I pulled it to bits - found out what the brushes inside an alternator actually looked like, replaced them - then put it back together.
best of all, it actually works now!
Postby Emperor » Wed Jan 09, 2008 2:03 pm
Sweet... Cheers.
Now.. Should I paint or polish my waterpump housing, intake mani, radiator overflow?
Emperor
Re: Few questions
Postby barryogen » Wed Jan 09, 2008 4:10 pm
Emperor wrote:dont want the surge tank to run out before the stock pump can put more into it
doesn't the return from the engine normally go to the surge tank?
although that would mean that the fuel would get warmed more.
barryogen
2ZZ Guru in training
Postby Emperor » Thu Jan 10, 2008 3:35 pm
yeah just got told that.
but apparentally need to change the intank one anyway, to a low pressure one, and a high pressure after the surge tank.
Emperor
Postby Trls250s » Thu Jan 10, 2008 3:40 pm
Do all RX7s come standard with huge holes in the wheel arches?
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby Emperor » Thu Jan 10, 2008 3:42 pm
Trls250s wrote:Do all RX7s come standard with huge holes in the wheel arches?
no we took th plastic covers out
Emperor
Postby evil_si » Thu Jan 10, 2008 4:11 pm
in my rx7 im using
standard intank pump to supply the surge tank,
then bosch pump from surge tank to engine,
engine return back to surge tank
and an overflow from surge tank to fuel tank,
if you run the engine return to surgetank you must run an overflow!! you will have no control over fuel pressure if you dont!
as for the alloy bits and polishing,
im leaning towards having them powder coated or if i find a money tree hpc'd, polishing looks cool, but is lot of work to keep shiney,
i polished all my intercooler piping 2 years ago done about 2000km and they are in desperate need for some polishing or coating!
evil_si
Postby IH8TEC » Thu Jan 10, 2008 4:27 pm
or procoating (refer my project) barry has a proper lifter pump that you can buy, it's designed to be able to run dry just in case you do run that low,
i however am using the std gze pump for lifter
-8 main feed (making my own lines, it's easy)
through fuel filter to a bosch o44 external pump
-8 line to engine bay with another inline filter to fuel rail
-6 return to fpr
-6 from fpr to surge tank,
-6 overflow from surge tank to fuel tank
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
