gx71 fuel pump relay location needed!
Postby docTRD » Fri Jan 11, 2008 12:43 pm
does anyone know the location in the car of the fuel pump relay in a 1985 gx71 cressida ? 1g-e engine. could be the same as a mx73 or mx83 not sure though. need it so i can get my engine going. cheers
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby thegreatestben » Fri Jan 11, 2008 12:50 pm
GX81 is drivers kick panel
thegreatestben
Postby KinLoud » Fri Jan 11, 2008 11:00 pm
Dude - might be near the original computer location... perhaps even mounted on the old computer???
I will have to pop around and have a look with you...
How is the corolla of doom going?
Ken
Ham
021 408 863
Postby docTRD » Fri Jan 11, 2008 11:27 pm
hey yea sweet man ive been lookin around for what normally looks like a relay so a black box with pins in it, (supposedly 5) and have wired traced it but cant seem to track where it goes, if heads into the dash somewhere or maybe into engine bay, dam tricky, yes you should come have a look :) ! . corolla of doom is goin well not very evil tho :p cheers
docTRD
Mo Joe
Postby matt dunn » Sun Jan 13, 2008 9:39 pm
toyotya's are usually a green relay with a 6 pin type plug, ( 5 wires used)
and on older stuff like that usually near the ECU.
Postby MrDori » Sun Jan 13, 2008 10:54 pm
should be abe to buzz really out on the main ecu plug using a negetive feed
Garage Slipway- Super rarity
1g-gte powered gx61 creditstar
MrDori
relay
Postby docTRD » Sun Jan 13, 2008 11:56 pm
found it was behind the drivers kick panel with a shiteload of fuses etc. seems like i wired it up properly . is it fine to just run the fuel pump with an ignition feed? or should it really be started by the ecu from the Fc output.
docTRD
Mo Joe
