****4agze turbo wont start now****
Postby corolla gt » Mon Jan 14, 2008 7:51 pm
hi i have had my motor running now and it pump out smoke but it isnt runn in at all and not tuned so dnt mind...but
now it wont start for some reason ..
it is getting fuel.and its getting spark but a very faint spark
would that be somethnig to do with my mitsubishi ignitor i am using but i have been told to use that ignitor as i have a link and the toyota 4agze ignitor doesnt work on link or something
but yea i got it startd quiet a bit i just cant see how it just wont start now?
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby l1ttle_d3vil » Mon Jan 14, 2008 9:46 pm
$10 says its the spark plugs. put new ones it and it'll start first go.
actually, make it $50. :roll:
Postby IH8TEC » Mon Jan 14, 2008 9:55 pm
do you even have a proper map for the engine to run on? is it all wired correctly, just step back and take a good look at the car, and think if you've missed something. more details is better. and check the basics first
Postby Zyros » Mon Jan 14, 2008 10:04 pm
l1ttle_d3vil wrote:$10 says its the spark plugs. put new ones it and it'll start first go.
Done, $50 says it aint :D
Zyros
Postby corolla gt » Thu Jan 17, 2008 10:23 pm
haha put new spark plus in started first pop its shhwwwweet now cheers dudes looks like theres 50 buck to be owed now ae haha
corolla gt
Postby bluemaumau » Thu Jan 17, 2008 10:48 pm
haha put your money where your mouth is
Postby l1ttle_d3vil » Thu Jan 17, 2008 10:53 pm
haha been there done that many times, itll be running too rich and fouling the plugs so will do it again unless you get it tuned.
weird thing with it is it will run perfectly fine, switch it off, then a few hours later it just won't start at all. in theory you'd think it would slowly run worse and worse THEN die.
