by postfach » Tue Jan 15, 2008 10:19 pm
yeah, if there's water pissing out, it should be pretty easy to find, fill the radiator with water again (when the car is cold) then start it, watch the engine to see where the water comes out, making sure that you don't run it dry. once you've found where the water is coming out, turn it off, and fix it.
