Why do i get a deep harmonic noise in my new rear muffler?
Postby Timoz » Wed Jan 16, 2008 12:07 am
Hi i got a Levin BZ-R with a blacktop in it, i just put on a new rear muffler of 2.25" straight through one.
The exhaust sound is very deep and i get a harmonic noise at around 2500-4000rpm. So what do you guys suggest for me to do to remove these deep harmonic noises and make the exhaust sound to be a higher pitch noise also been quiter. one more thing i still got the CAT installed. Cheers
Timoz
Re: Why do i get a deep harmonic noise in my new rear muffle
Postby barryogen » Wed Jan 16, 2008 8:26 am
What else is the exhaust from the headers?
you say you still have the cat, and then is it just the factory piping(no resonators?) to the new rear muffler?
barryogen
2ZZ Guru in training
Postby Timoz » Wed Jan 16, 2008 6:59 pm
Yea just factory piping with no resonators to the new rear muffler.
Timoz
Postby Simon K » Wed Jan 16, 2008 7:01 pm
Put your old muffler back on.
Simon K
TS Wannabe
Postby Bling » Wed Jan 16, 2008 9:07 pm
or if that one is stuffed... which i'm hoping is the reason you put a new muffler on....... not for wank factor I hope!!
put another muffler in the pipe somewhere between cat and fart cannon
Postby Timoz » Wed Jan 16, 2008 11:20 pm
Shoudl i put a coby resonator in between the CAT and the rear muffler? if not a coby what size and where shoudl i get this muffler from? Any good suggestions?
Timoz
Postby tsoob » Wed Jan 16, 2008 11:34 pm
BZG|Bling wrote:put another muffler in the pipe somewhere between cat and fart cannon
AWESOME!!
tsoob
Postby barryogen » Thu Jan 17, 2008 8:40 am
Timoz wrote:Shoudl i put a coby resonator in between the CAT and the rear muffler? if not a coby what size and where shoudl i get this muffler from? Any good suggestions?
resonators tend to take our higher pitched noises, you need a proper muffle, like is in there from factory, as large as will fit usually does it.
Any muffler shop has them, and will happily fix what you've done to it.
barryogen
Users browsing this forum: Bing [Bot] and 16 guests
