roll cage in jza70
roll cage in jza70
Postby MRDRFT » Tue Jan 15, 2008 8:08 pm
has anyone had a roll cahe put in their JZA70?if so do you have the scale drawing of the cage that you used to get the pipes bent up,im building a drift car and geting the cage bent up and im welding it in,but i cant be bothered drawing a scale drawing of the cage ,as im not the best drawer.haha,any help would be grate!
thanks
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby fangsport » Tue Jan 15, 2008 10:23 pm
why would you need a scale drawing?
take the interior out and take it to Dave McCahon or Raycroft and get them to bend it for you. dave may even be able to do the kit for that car, as he keeps everything on file.
fangsport
Postby Leon » Wed Jan 16, 2008 7:16 am
exactly what I was thinking.
Postby fangsport » Wed Jan 16, 2008 5:41 pm
Leon wrote:exactly what I was thinking.
my guess would be that he has an engineer mate that has never done a cage before and thinks he can bend the tubing successfully without ovalising beyond tolerances, but is still prepared to waste a couple of hundy worth of steel proving himself wrong!!
fangsport
Postby MRDRFT » Wed Jan 16, 2008 10:52 pm
na i rung auto bend and they dont have the kit on file so want a scale drawing to work out cost and then bend the pipes up.
210kw atw on 12psi
223kw atw on 12psi
MRDRFT
Postby Leon » Thu Jan 17, 2008 7:14 am
Dave
0274 341 541
SMS cages
Postby slammed_integral » Thu Jan 17, 2008 3:56 pm
look up japanese products, they have kitset cages for loads of cars, find a image and copy that
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
Postby fangsport » Sat Jan 19, 2008 5:38 pm
slammed_integral wrote:look up japanese products, they have kitset cages for loads of cars, find a image and copy that
real good idea, then spend all the effort copying a design that dosn't comply in NZ.
fangsport
