st185 gt4 dripping water constant
Postby dvmv_kim » Fri Jan 18, 2008 3:25 pm
i posted up before saying my car overheated then coolant was dripping out in the middle somewhere i had a look and i cant really see cause of the brace thats holding the engine will anyways i filled the radiator up with water and it just drips water constant went for a 10minute drive to see if would over heat, temp was normal then parked the car up and the water started to drip a bit faster after that drive. any ideas? or shall i take it to the garage and see how much it would cost?
dvmv_kim
Postby dvmv_kim » Fri Jan 18, 2008 3:32 pm
just wondering 2 weeks ago i did put new coolant in the radiator and maybe it was too strong or too weak? so it might cause it to leak? just a suggestion
dvmv_kim
Postby rollaholic » Fri Jan 18, 2008 5:26 pm
theres alot of places for water to leak on an engine, if its from the engine (rather than the radiator) somewhere it'll be the waterpump (mildly expensive) or some random heater hose / water line. (not so expensive).
coolant strength (or lack of) wont cause leaks in the time frame you are looking at, although lack of inhibitor will cause rust in pipes / water galleries in the long term.
half coolant half water is a good mix.
Postby Boosted_162 » Fri Jan 18, 2008 6:41 pm
Get a picture of the area its leaking from, and ill get photos of the waterlins around there cos my motors on the floor
Postby cedwards » Fri Jan 18, 2008 7:40 pm
did you bleed the thermostat when doing coolant change?
cedwards
Postby dvmv_kim » Fri Jan 18, 2008 9:18 pm
Boosted_162 wrote:Get a picture of the area its leaking from, and ill get photos of the waterlins around there cos my motors on the floor
okay cheers man i will do this tomorrow
dvmv_kim
Postby dvmv_kim » Fri Jan 18, 2008 9:19 pm
cedwards wrote:did you bleed the thermostat when doing coolant change?
no i didnt just put new coolant straight into the radiator
dvmv_kim
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
