W57 into KE2# tunnel. Does it fit?
Postby ke25sr » Fri Jan 18, 2008 8:00 pm
title sums it up really.
Do i need to modify my tunnel to fit the W57 box?
ke25sr
Postby l1ttle_d3vil » Fri Jan 18, 2008 9:15 pm
its definitely possible, but is a very tight fit. mine probably rubs on the tunnel in a couple of spots but could probably have been mounted an inch lower or something.
can be done without cutting and welding the tunnel anyway.
Postby ke25sr » Sat Jan 19, 2008 8:56 am
Great man. Thanks. Did you have to make a new X member or did the factory item work with slight mods?
ke25sr
Postby l1ttle_d3vil » Sat Jan 19, 2008 12:08 pm
pretty sure it is the factory xmember with the w5# mount attached. will PM some pics shortly.
