2JZGTE gearbox Convertion
Postby NZVengeance » Tue Jan 22, 2008 3:30 pm
Now i know it is possible to make this 4wd i have been assured by a guy in waihi (Conversion components) that it can be done my question is what is the best way to go?
Hilux Box?
GTR34 Skyline box?
other?
Hypothetically speaking would want a box that would support 650-800bhp
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
He who dies with the most Toys wins!!
NZVengeance
Postby NZVengeance » Tue Jan 22, 2008 3:34 pm
at the moment this is just a working theory so not jet set in stone. just wanted some thoughts and ideas from ppl. no criticism please just positive advice or options.
Albert Einstein
NZVengeance
Postby IH8TEC » Tue Jan 22, 2008 3:41 pm
so what to put a 2jzgte into a front wheel drive? more details might make what your suggesting clearer
Postby NZVengeance » Tue Jan 22, 2008 4:21 pm
EDIT: sorry that was a miss type on my part was supposed to be 4wd not fwd
Albert Einstein
NZVengeance
Postby Bling » Tue Jan 22, 2008 4:36 pm
and into what car?
Postby flygt4 » Tue Jan 22, 2008 5:03 pm
may pay to look up TWSTD's altezza wagon thread, his is a factory 4wd 2jzge , and it had a few clues on how to do it on there.
flygt4
Postby d1 mule » Tue Jan 22, 2008 5:34 pm
or W56 hilux box with W-J belhousing from nite-b on here.
would help if we knew the car tho
d1 mule
Postby postfach » Tue Jan 22, 2008 8:05 pm
A W series box won't hold that much power, you want something out of newer GTR or perhaps an Audi Quattro (if you see the box from one of these, you'll see why I suggest it, they're rather significant). You'll either have to get a custom bellhousing cast or design an adaptor plate
With the GTR box, you'll probably end up having to sit the engine quite far back so you have room to mount a diff in the front since the GTR diff is in the sump, and you can't use it.
The Audi boxes I've seen have the front axles coming out the side, just behind the bellhousing, so to use that you'll need a car with a fairly long nose to fit the 2J in there.
Either way, there's lots of fabrication needed.
Anyone else have ideas?
postfach
Postby IH8TEC » Tue Jan 22, 2008 8:25 pm
ideas, not without knowing type of car
Postby flygt4 » Tue Jan 22, 2008 8:45 pm
my theory is if you were going to be doing 650-800hp then you would be inclined to buy a decent sequential box and setup and do all the fabrication required to fit it to your application
ask matt dunn about crazy conversions, he seems to have been involved in a few , and funnily enough they don't often try to use factory parts for a purpose they were never designed for. i think they had a hollinger or something in their xr6T focus.
flygt4
Postby matt dunn » Tue Jan 22, 2008 9:52 pm
flygt4 wrote:my theory is if you were going to be doing 650-800hp then you would be inclined to buy a decent sequential box and setup and do all the fabrication required to fit it to your application
yeah if you want that much power, there is not m uch apart from a hollenger that I can think of that will take it.
The 4WD skyline that races in my class is supposedly 600hp or so and is hollenger sequential and 4wd, but the lower power skylines still break modified GTR boxes so they are not that good either?
In fact we managed to shatter a hollenger input shaft in the focus with the torque.
Are you talking circuit or drag racing?
Postby Si » Tue Jan 22, 2008 10:11 pm
May be investigate whats in the 4wd aristos in terms of driveline, from memory they are 1UZ only and probably arnt that strong but it might be a start
Current: , '96 SubaruImpreza
Si
Postby Dell'Orto » Tue Jan 22, 2008 10:16 pm
matt dunn wrote:but the lower power skylines still break modified GTR boxes so they are not that good either?
Comparatively, they're not that strong. The Trust/Greddy gearsets you can buy for them still smash at around 550hp.
Postby matt dunn » Tue Jan 22, 2008 10:37 pm
It's not Hp that breaks stuff it's torque.
The 2JZGTE AE101 Levin runs a hollenger same as the Focus,
and the same diff and axel's
and has had no power related drivetrain problems,
and made more HP than the focus.
But the focus had almost tripple the torque lower in the RPM range,
just over 880nm at the fly,
and so shat a few diff's axels and the hollenger.
Postby postfach » Tue Jan 22, 2008 10:45 pm
Depending on how you look at it, this could be seen as off topic, but:
Matt - Regarding the Hollinger for the 2JZ, was there a bellhousing available or did you have to get something made?
postfach
Postby matt dunn » Tue Jan 22, 2008 11:02 pm
postfach wrote:Depending on how you look at it, this could be seen as off topic, but:
With hollenger, everything is custom made, even the input shaft,
so a 6 month wait when you break it, lol.
The guys that own the AE101 are Toyota dealers so they supplied us with a brand new genuine toyota bellhousing and we made the adapter from there.
Postby strx7 » Wed Jan 23, 2008 6:54 am
R150f or R151f
They are essential a R154 for hilux's. Thats what I have behind my 2JZ-GE, they are the 3VZ-E and 3KZTE gearbag. They use a W5# style clutch fork as apposed to hydraulic.
the difference between those 2 is the 5th gear ratio (thats the difference i picked up on while driving the 2 different boxes
Postby 2jayzgte » Wed Jan 23, 2008 7:30 am
Why not just use the Getrag 6-Speed out of a JZA 80 that should do the job.A Hollinger Sequential box are'nt they like $20 K??????
2jayzgte
Postby NZVengeance » Wed Jan 23, 2008 8:09 am
is there anyone in NZ like holinger or getrag. was goign to try and avoid them simply because of the hassle if anything breaks.
don't worry about what car it is going into that is of no consequence. fabrication is not an issue and i assure you it will fit.
Albert Einstein
NZVengeance
Postby postfach » Wed Jan 23, 2008 2:58 pm
2jayzgte wrote:Why not just use the Getrag 6-Speed
Because it's not 4WD....
postfach
Users browsing this forum: No registered users and 33 guests
