postfach wrote:I would imagine that there will be no problem using the next size down, of course, you'll need the appropriate sized nut and a washer, I'd use a nylock.
Shouldn't cause any issues since the nut is really only there to make sure you don't pull the wheel back off the spline. I don't know about you, but I don't go yanking backwards on my steering wheel for kicks .
Malcolm wrote:wanna know how I would fix it if it's stuffed beyond repairing the current thread? Drill the centre out, tap it, then put a bolt and washer on to hold it in. If it's an M12 then a M8 would be sweet, all you'll need is a 6.5mm drill bit, an M8x1.25 tap and a suitable bolt & washer.
This would be far better than trying to put a smaller pitch thread on it (smaller pitch = larger thread root diameter so you'll have even less material holding it on), and easier than trying to find another thread that happens to be just enough smaller to be able to be cut without first reducing the diameter of the column
Malcolm wrote:wanna know how I would fix it if it's stuffed beyond repairing the current thread? Drill the centre out, tap it, then put a bolt and washer on to hold it in. If it's an M12 then a M8 would be sweet, all you'll need is a 6.5mm drill bit, an M8x1.5 tap and a suitable bolt & washer.
