Mike- wrote:~SlideWays~ wrote:I did it on a remote control car once, no problems there.
yeh tamiyas are easy as, tycos are a whole new kettle of fish though
Akane wrote:But your rear diff will probably cry as it's not designed to take all the power instead of sharing the load along with the front wheels.
Trls250s wrote:Cut out a transmission tunnel in the car and stuff a altezza box and rear in a gt4 would be the way to go.
barryogen wrote:and magically the n/s engine will bolt right up to the factory mounts made for e/w... not to mention being down on power, and the flex you would have in the chassis because it's not designed for a n/s engine config.
