matt dunn wrote:It's not Hp that breaks stuff it's torque..
Was easier to say 550hp than 400+-20% ft/lbs
NZVengeance wrote:is there anyone in NZ like holinger or getrag. was goign to try and avoid them simply because of the hassle if anything breaks.
don't worry about what car it is going into that is of no consequence. fabrication is not an issue and i assure you it will fit.
narlystarly wrote:I thought school hols were over?
my theory is if you were going to be doing 650-800hp then you would be inclined to buy a decent sequential box and setup
NZVengeance wrote:well narlystarly you can take you comments and stick em where the sun don't shine. they are not welcome nor warranted. perhaps you should go and find something more useful do do with your time and leave alone those of us who might want to use this forum as a knowledge gathering exercise.
and FYI not a school kid. 21 in the software industry and just getting into the modification of cars. so yea i dont know much. HENCE the post.
narlystarly wrote:If you are now serious on the high power gt4 check into the toyota echo i believe it was in the uk running st205 3sgte lots of power and ran consistent 10s. Very sleeper. Not sure if he was running a custom box/diffs/xfer case etc, but seemed to be a very good package.
barryogen wrote:
There is a 4wd Corolla running a 3sgte...
