radiator question
radiator question
Postby NOLAW » Fri Jan 25, 2008 2:07 pm
i have a custom radiator and have just had an outlet modified and am just worried about the bit thats been welded on being to short for a hose and clamp to be fitted, iv drawn a illustration below showing how the outlet goes and a measurement (overall veiw is from the top/looking down)
basically what im wondering is will i get a hose and clamp on here sweet and is there a chance of it poping off when in use?
NOLAW
Postby sergei » Fri Jan 25, 2008 2:50 pm
if you have rib on the end it should be fine.
Postby evil_si » Fri Jan 25, 2008 2:54 pm
does seem a bit short,
as sergei said if there is a rib it should be ok if you use a thin hose clamp.
if not take it back,
evil_si
Postby NOLAW » Fri Jan 25, 2008 3:56 pm
the rib is about half way, what are the chances of the hose blowing off if i seal and clamp it on to the outlet?
NOLAW
Postby sergei » Fri Jan 25, 2008 3:58 pm
if the clamp is positioned after the rib (further in), and the hose has some slack it should be fine. Use screw on type of clamp (not spring).
Postby l1ttle_d3vil » Fri Jan 25, 2008 5:21 pm
that should be plenty, the water lines don't have a massive amount of pressure. but it seems a bit weird with the rib in the middle...
i've got plenty of water hoses without ribs at all and never had any leak / pop off :twisted:
Postby NOLAW » Fri Jan 25, 2008 6:10 pm
sorted cheers guys
NOLAW
Users browsing this forum: Bing [Bot] and 17 guests
