Oh and also how much do you reckon id be able to fetch for a 1992 ae101 trueno silver lowerd springs mags(abit $$%), full exhaust system, race steerin wheel momo pedals, 145ks and looked after by a toyota mechanic???? Just out of interest
barryogen wrote:I'm looking at them at the moment, the only bad thing I have heard is gas consumption, although for a 190kw wagon, it seems pretty good.
They are fast enough, do a high 13 low 14 second quarter mile, although to do that you apparantly have to ride it verry verry hard.
From reading they appear to have minor problems with left rear wheel bearings, and the aforementioned manifold issue, but nothing too serious.
The engine/drivetrain appears to be generally bullet proof on all accounts.
Clutch is no more expensive than getting any other 4wd one done, so no matter which one you bought you'd be paying for it, so can generally be ignored.
They are fairly boring inside until you get to the ST246(the newer rounder ones, 2002{?} onwards), but they only came in auto, so I havent looked at them much.
$10k will get you an average one, $12k a better one, $18k seems to buy you a low kms 2000/2001(only I think production stopped in 2000 so can't explain that one).
I'm looking at either a 98 with 150kms on it for cheap(under $10k), or one around the $14k mark(low ish kms, 01)... havent decided yet.
barryogen wrote:The engine/drivetrain appears to be generally bullet proof on all accounts.
Dell'Orto wrote:barryogen wrote:The engine/drivetrain appears to be generally bullet proof on all accounts.
They're alot more fragile than previous incarnations of 3SGTE, there have been alot of instances of bad fuel making them go bang.
barryogen wrote:Dell'Orto wrote:barryogen wrote:The engine/drivetrain appears to be generally bullet proof on all accounts.
Wouldn't that be a tuning issue(less tolerance for bad gas) rather than a problem with the engine?
I know I'm arguing a minor point, but if modding them then aftermarket management should sort any issues with bad gas assuming you have a decent tuner.
