Correct procedure to remove 4age crankshaft key?
Postby ~SlideWays~ » Thu Jan 31, 2008 3:23 pm
So does anybody have tips on how to remove a key from a 4age crankshaft key without damaging it?
I have a bit of a project car that has a broken key, the keyway looks fine so was just going to take the key from a parts engine...but fk me the bastard won't move, swimming in CRC and all! :lol:
Any help would be appreciated.
~SlideWays~
Postby Trls250s » Thu Jan 31, 2008 3:42 pm
I dunno why but 4ages always get real siezy around that area of the crank. Ive had to drill off 2 cam belt pulleys off engines before just to get the crank out to do bearings.
You could try a cold chisle or cooling down the key/heating up the crank (not to much tho). To much heat and you could seriously $&#$% the crank, and beating it might not be the best idea.
Might be easier to buy a key from an engineering supply store or get one made instead.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby AceSniper » Thu Jan 31, 2008 5:50 pm
toyota do new keys for like $4? or less
tap it on one end with hammer and punch, it will turn and lift out the other side... been half moon shape
AceSniper
Postby Crucible » Thu Jan 31, 2008 6:12 pm
yep as above tap the front 1/4 of the key and the back half should rock/lift out.
Crucible
Real Life Mechanic
Postby l1ttle_d3vil » Thu Jan 31, 2008 6:53 pm
True-No-Turbo wrote:yep as above tap the front 1/4 of the key and the back half should rock/lift out.
3rded. works mint.
Postby rwd_mayhem » Thu Jan 31, 2008 7:41 pm
that doesnt always work, i ended up having to get a new one and the one i was trying to get off is still on the end of the crank of another engine.
current: 1975 Valiant Regel
rwd_mayhem
Postby Crucible » Thu Jan 31, 2008 11:14 pm
how can it not move if you hit it from the top with a hammer? it has no choice....
Crucible
Real Life Mechanic
Postby ~SlideWays~ » Fri Feb 01, 2008 8:31 am
LOL at $4 I'll just get a new one. Cheers guys, hopefully i can get the broken half out too.
~SlideWays~
