how do i install a top break light? fxgt
Postby fx gt » Thu Jan 31, 2008 8:59 pm
wanting to put a rear top break light in my fx wagon, went and got bulb holders that aldery had the wires for break light hooked up but it dosnt work
its fine with out the park lights on, but when ya turn them on so does the top break light
also the clock likes to dim when foot is placed on break
anyhelp with how id go about hooking it up proply?
fx gt
Postby 20v_rollaboy » Thu Jan 31, 2008 9:51 pm
Did the clock light dim before you hooked up the high stop light?
If not, thats another problem :?
Your other problem sounds like your brake and light wires are touching somewhere??
20v_rollaboy
Postby Ae92typeX » Thu Jan 31, 2008 10:18 pm
as above, or I'd question the 'origional wires' as it sounds like you have it earthed through the light feed.
Ae92typeX
Postby fx gt » Thu Jan 31, 2008 10:30 pm
20v_rollaboy wrote:Did the clock light dim before you hooked up the high stop light?
yeah think it has dimmed before it. cant think of where the breke and light wires could be touching :(
thanks for your reply
fx gt
Postby 20v_rollaboy » Thu Jan 31, 2008 11:26 pm
Where have you taken the feed for your high-stop from? Maybe try earthing it on the body, and only running one wire down to the brake light.
20v_rollaboy
Postby Bling » Thu Jan 31, 2008 11:47 pm
sounds like the wires you found already there are hooked up to the park lights rather than brake lights....
when you say its fine without the park lights on, do you mean it functions correctly?
easy fix is just run a new wire from a brake light.... no problems then.
Users browsing this forum: Yahoo [Bot] and 5 guests
