BZG|Bling wrote:the size of your wheels makes no difference to the revs the guage will show at a certain speed. if they are different overall diameter to factory tho, the speedo will be out
[/quote]GDII wrote:
Big-ben-007? Have you noticed a flat spot in the power around 2000rpm? Mine does from 1000-2500rpm then takes off, with the little power it does have![]()
xsspeed wrote:BZG|Bling wrote:the size of your wheels makes no difference to the revs the guage will show at a certain speed. if they are different overall diameter to factory tho, the speedo will be out
meaning wheels plus tyres, if you know the overal gear ratios you can work out roadspeed from revs, or vice versa
[/quote]GDII wrote:Big-ben-007? Have you noticed a flat spot in the power around 2000rpm? Mine does from 1000-2500rpm then takes off, with the little power it does have![]()
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
