calculating ltr capacity.
Postby Infinite » Sun Feb 03, 2008 9:11 pm
how would one find out how many ltrs a 330l x 220h x 330w fuel cell is had a look on google but only found ones for body mass lol
Lots
Infinite
Postby Matty104 » Sun Feb 03, 2008 9:18 pm
approx 23 24 litres? i could be wrong tho
but volume is l x w x h
then if you find the formula to turn volume into litres youll find out,
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby 20v_rollaboy » Sun Feb 03, 2008 9:20 pm
If youre really stuck fill it up with water from a measuring jug :D
EDIT: 23 Litres :o , maybe not......
20v_rollaboy
Postby Infinite » Sun Feb 03, 2008 9:20 pm
lol its half full of av gas :P
Lots
Infinite
Postby Bling » Sun Feb 03, 2008 9:26 pm
Matty104 wrote:approx 23 24 litres? i could be wrong tho
thats correct.... 10mm3 is 1ml so it can't be hard to work out with a calculator. basically 24L
Postby Matty104 » Sun Feb 03, 2008 9:28 pm
:wink:
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Matty104 » Sun Feb 03, 2008 9:29 pm
20v_rollaboy wrote:If youre really stuck fill it up with water from a measuring jug :D
:lol:
dissregard that last post to , dunno what i was up to, its just too hot thesedays
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Grrrrrrr! » Sun Feb 03, 2008 9:30 pm
0.33m * 0.22m *0.33m = 23.9L total volume
so it would hold around 20L of fuel i'm guessing.
And the atl fuel cells catalog has an entry which looks pretty close :)
Code: Select all
Model Capacity  Length   Width     Height  Bladder
SA105 20L       330mm    330mm     229mm   AL105
Grrrrrrr!
