tuner
tuner
Postby themaleman » Sun Feb 03, 2008 1:02 pm
ok probly been touched on a few times but im after an up-2-date answer.
who recomends where to have a 4agte weird and tuned?
any 1 do it themselfs?
im about to put my engine in the car but want to sus out where to get the link weired and tuned first so i can check with the tuner that im heading in the right direction as far as the install goes.
any sudgestions apreciated
thanks
liam
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Adydas » Sun Feb 03, 2008 1:04 pm
Let me see how my tune comes out before i reccomend him, but hes been on to it replacing anything as it fails to provide a solution to somthing thats not yet become a problem... Id rather wait longer while he finds a rusty leak in the fuel tank than get it back and have to take it off the road agian..
Adydas
Postby flygt4 » Sun Feb 03, 2008 2:10 pm
andre at speedtech has a lot of experience with 4agte's. he seems to know how far he can take them before they become unreliable (probly experience from blowing a few up).
he tuned my car to 218kw atw , slideways car to ~210atw , and also trueno_turbo's car to ~210kw atw, all running with link ecu's.
they are able to wire them too.
if you ask nicely/bribe someone, someone from here might give you their map as a starting point, potentially saving you 100's of $$$ in dyno time. i can't help you there as i don't have a usb port on my link so don't have the right gear to access my map.
good thing about 4agze turbo's , is that they are very hard to break, and will survive poor a:f ratios for quite a while. they tend to run bearings,blow oil and have issues like that instead of dropping pistons etc.
any half decent tuner will be able to get good results out of a dyno tune if your engine is up to it.
i suggest you ring around a few potential tuners, ask about pricing, dyno hire charges, expected time to build a map form scratch etc, and what experience they have with the engine.
flygt4
Postby IH8TEC » Sun Feb 03, 2008 5:14 pm
i used gavin bellars at hi velocity in wairau, tunes nice and conservative, ie mines quite rich, but still good power, and we all know my 196kw has proved itself on the 1/4mile aye jeremy :lol:
really good guy to deal with, you'll just have to check with him as he's normally pretty busy. also does a really good road tune afterwards, ie mine is really fuel economical when cruising light throttle (passing) etc. can get 500km on a tank.
number is 442 4451
Postby ~SlideWays~ » Sun Feb 03, 2008 6:42 pm
flygt4 wrote: slideways car to ~210atw
BAH! its 212kw's! :lol:
~SlideWays~
Postby flygt4 » Sun Feb 03, 2008 6:59 pm
thats still 6 less than 218 :wink:
flygt4
Postby themaleman » Sun Feb 03, 2008 10:42 pm
haha cheers people, keep the tuners comming,
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Sun Feb 03, 2008 10:49 pm
IH8TEC wrote:i used gavin bellars at hi velocity in wairau, tunes nice and conservative, ie mines quite rich, but still good power, and we all know my 196kw has proved itself on the 1/4mile aye jeremy :lol:
number is 442 4451
does he install the ecu etc as well?
4x4 toyota blizzard offroader
escortman
Postby mjrstar » Mon Feb 04, 2008 10:02 am
i would fully reccomend kent form speedsource in warkworth(0214dynotune). awesome rates and tuned my internally stock 1ggte to over 240kw atw. really friendly helpful dude as well.
i beleve he has tuned a 4agte to over 315kw with a gt30/40 strapped on the side.
unsure if he would be interested in wiring your ecu.. couldn't hurt to ask though.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby themaleman » Mon Feb 04, 2008 10:24 am
sweet ive called him - hes happy to do the wiring and dyno tune.
also called gavin, he'll do it iswell, costing a bit less than kent but i would have to wait like 3 months where as kent can do it in a week!
4agte ae92 Levin
a15 powered sj410
themaleman
Postby escortman » Mon Feb 04, 2008 5:44 pm
themaleman wrote:sweet ive called him - hes happy to do the wiring and dyno tune.
sweet ill get him to do mine 2. how much is it costing u?
escortman
Postby IH8TEC » Mon Feb 04, 2008 6:07 pm
yeah kent was the other one i was trying to think of, i'll "most likely" be going to kent for a retune when i change a few things around later on as gavin doesn't "really" like tuning road cars much leaner. but he will if you really want him to, you'll get a nice safe/reliable/good power tune from him. safe and reliable being key words.
if you wait for him, dont worry about the figures his dyno says, they are all different.
Postby gasman » Mon Feb 04, 2008 6:20 pm
so who has a map for a 20v 4agte i can borrow for my tune. ill give it back i promise. its for a link LEM G3 BTW if that makes a difference.
"What can possibly go wrong?"
gasman
Postby sk1dlet » Mon Feb 04, 2008 6:36 pm
i wouldn't mind a good base map for my 16v 4agte running a lem v5 would any one be able to help in that area?
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby moses » Mon Feb 04, 2008 7:12 pm
ive got a good base map on a link lem g3 for a 20v 4agte if you want it gasman
moses
Postby gasman » Mon Feb 04, 2008 7:45 pm
send it to justinsue@hotmail.com do i just load it onto the link as per the instructions?
gasman
Postby IH8TEC » Mon Feb 04, 2008 7:56 pm
basically plug ecu in to computer, click load, will bring up whats on there atm,
click open, select his map, click ok, click store or save, and tick save settings to ecu or something along those lines, then click ok
also, you MUST make sure your outputs/colour wires are the same, or change them around to suit YOUR loom. and make sure you have same sorta ignition stuff, or change to suit YOUR setup,
brendon
Postby themaleman » Mon Feb 04, 2008 8:24 pm
a good base map for a 16v 4agte on a lem v5 is exactly wat im after! ive got serial link 2. yea kent will hopfully by doing mine,
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Paulio » Mon Feb 04, 2008 9:47 pm
car isnt quite going but only a few days away, could really do with a 16v turbo map for lemv5 also if anyone has one :P possibly be a mile off mine but atleast I can see a map from something that runs nicely.
:D
Paulio
Postby Crucible » Tue Feb 05, 2008 1:05 pm
gasman wrote:send it to justinsue@hotmail.com do i just load it onto the link as per the instructions?
lol, wheres you're manners man?. you do realise it can cost alot of $$$ in dyno time to build a map from scratch, you should be very thankful the guy offered it to you!
I would only give it to mates I know, everyone else can pay!!!!!
Crucible
Real Life Mechanic
