****help me anyone 4agze problem will pay****
Postby corolla gt » Mon Feb 04, 2008 7:44 pm
if anyone local could ome check my car out b4 i take to a mechanic becuase not much mechanocs no about 4agze turbos
i will pay for the gas for them to get to my house and pay ya 2 check it out please :(
4agze with td05 :?
i have got a problem now that i cant solve.i have been told by a shop that my motor isnt running on4 cylinders and it is pumping out alot ov smoke out of the exhaust
i have put 2much oil in the motor for starters and now i thnik the oil has gone into the exhaust and thats why it is pumping out smoke...i have had 2 put new turbo on as the last 1 was blowin and oil was pissing out ov the inlet of turbo
i am starting to get oil come out of the turbo again but it is behind the perpaler and not seeping out like the last 1.
cant find out why it is runnig on 3 cylinders and have since done a compression test on it.it was about 160 to 165 on all the 4 cyclinders on a dead cold motor (is that even a good number?) i cant runn it in warm as i dnt want to blow motor up because not shore it is running properly its a fresh rebuilt motor
any ideas what i should do or is anyone local in wellington that could check as i dont have a clue and am not keen to blow any more stuff up on my motor and it is begining to cost me alot of cash
CURRENT:TOYOTA 1993 Hilux surf
OLD:TOYOTA 1995 HIACE SUPERCUSTOM TOYOTA SPINTER GT 1985,TOYOTA COROLLA GT 1986 (SMALLPORT)
corolla gt
Postby evil_si » Mon Feb 04, 2008 8:08 pm
for the smmoke, take the turbo off, block the oil feed and run it. check for excessive smoke
for the missfire replace the spark plugs, get the leads tested, or try another set
check the injector plugs
evil_si
Postby corolla gt » Tue Feb 05, 2008 5:03 pm
do u mea take the turbo off frm the maifold beause i have exhaust wrapeed the bolts so i cant take of wat if i just took the frnt ov it off and blockd the hole up?
corolla gt
Postby evil_si » Tue Feb 05, 2008 8:25 pm
no take the entire turbo off, its only heat wrap just take it off, this method should tell you if its the turbo of if its the engine!
dont run engine with turbo on and no oil feed turbo will be fkd in seconds!
evil_si
Postby Mr Revhead » Wed Feb 06, 2008 9:04 am
what colour smoke out the exhaust?
do you know which cylinder its missing on? if so pay close attention to the lead/plug/injector to that cylinder
have you drained out the excess oil?
Postby corolla gt » Mon Feb 11, 2008 8:38 pm
the smoke is grey
i checked all the plugs and leads and its sweet
i have just drained out enough oil so it has rite aomunt now
its just getting alot of fuel on the top ov the pistons so it must be flooding real bad i have 440cc injecters and link computer im thinking maybe injectors wired up wrong or got a wrong timing?
corolla gt
Postby moses » Mon Feb 11, 2008 9:05 pm
check your injector relay and timing and check 4 a masive air leak i had the same prob with my 4agte 20v wen i first wired it up
moses
