primering my car
primering my car
Postby trdtrueno » Sun Feb 10, 2008 6:56 am
im going to be prepping my car for a full paint job, and i was just unsure that if i primered the car and drove around in it for a couple of days would that be bad at all for the car ie reguarding primer???is it ok to leave it on and have no problems with rust or anything?? any help appreciated. cheers
trdtrueno
Postby rollaholic » Sun Feb 10, 2008 8:11 am
from what i have been told its not the best - apparently conventional primer absorbs water fairly readily, and if you drive it you risk not only getting rained on, but you will also need to wash it before it gets painted to get rid of the dust etc it will pick up - another chance for it to absorb water.
though if you are doing the prep work yourself, i guess you arent too concerned about the finish ;)
primer
Postby lowseven » Sun Feb 10, 2008 11:45 am
dont worry you dont wash your car before painting lol
2k primer is porus so it absorbs moisture but it aint a prob driving round in primered cars i done it for 8 months, blocked it back hit it base an clear and 3 years later no probs even the exposed spots that got 1k wash primer
lowseven
Postby tsoob » Sun Feb 10, 2008 12:27 pm
yeah as long as you use good 2k primer (not the stuff from a can) you can leave it my roof is primer atm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Anth_555 » Sun Feb 10, 2008 6:36 pm
i hope your gona strip the car befor you rub it back and prep it
the primer will have to be sanded and clean with prepsole befor its painted so i wouldnt worry about washing it
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby trdtrueno » Sun Feb 10, 2008 10:21 pm
yea cars gunna be stripped first ofcours....one question, about those rubber seals in the doors....do they just pull off or once i take them off do i need new ones??? cheers
trdtrueno
Postby Anth_555 » Mon Feb 11, 2008 7:19 am
which seal is it the one that runs round the door?
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby trdtrueno » Mon Feb 11, 2008 7:08 pm
yea the one that goes around the door....but dont worry, i took it off just now so its allgood. cheers guys
trdtrueno
