Pod filter or Ramflo???
Postby smack » Mon Feb 11, 2008 12:49 am
hey guys. im needing help with my carburated toyota corona, i wanna put some sort of new intake system on it, but im not sure whether i should put a poddy on it or a ramflo, seeing as its carbied and all. itz an '89 corona sedan. what do you guys reckon will be the best/easiest?
i though i could just take the panel filter out of the airbox, and put a podfilter onto the pipe that runs into it, however the only place i can easily do this looks like it will be taking some sort of sensor out of comiision(i have a funny feeling its air/fuel seeing as its running off the intake and into the carby some where), and im not sure wheter or not i should do this.
any help much appreciated!! thanks guys
smack
Postby d1 mule » Mon Feb 11, 2008 5:19 pm
just buy a new replacement fram or similar...
d1 mule
Postby Paulio » Mon Feb 11, 2008 9:28 pm
that sensor may just be something like idle speed control (mine revs up at start-up). should be piece of piss to install ramflo on top of the carby, may be noisy tho.
Paulio
Postby Prymal » Tue Feb 12, 2008 12:47 am
youd be better off leaving a panel filter in there dude .. All your gunna get is a bit more sound , thats about all
Prymal
