Smallport into an AE82 - Need wiring info
Postby pc » Sun Feb 10, 2008 8:34 pm
I have recently aquired a smallport 4AGE from a wrecked AE92 and want to put it in an AE82 that I have.
Bolting it in doesn't seem to be a problem, but the wiring seems to be completely different. All of the plugs are different on the engine looms and so are the plugs/sockets on the ECU.
Has anyone done this or have any idea which would be the easiest way to modify the engine loom to make it work?
I'm no auto sparky and could probably figure it out eventually... but if anyone has an idea how to do it simply, any input would be appreciated.
Also if someone has some reliable pin out diagrams of both ECUs that would also be useful.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ChaosAD » Sun Feb 10, 2008 9:29 pm
Most people just swap the bluetop electrics (dizzy, injectors, ecu etc) onto the redtop.
But id say youd get more power if you rewire the loom and run the redtop ecu etc
ChaosAD
Postby pc » Sun Feb 10, 2008 9:33 pm
ChaosAD wrote:Most people just swap the bluetop electrics (dizzy, injectors, ecu etc) onto the redtop.
Hehe... no way am I doing that. I want to try and get more power :lol:
red car
Manfield - 1:24s
pc
Postby rollaholic » Sun Feb 10, 2008 10:11 pm
get a complete smallport setup if you want all the benefits!
Postby escortman » Sun Feb 10, 2008 10:51 pm
iv got a complete smallport motor and loom just missing ecu, so to put into a ae82 is just swap looms ? and get a smallport ecu
4x4 toyota blizzard offroader
escortman
Postby pc » Mon Feb 11, 2008 12:35 am
rollaholic wrote:get a complete smallport setup if you want all the benefits!
Do you have a loom that will plug into an AE82?
escortman wrote:iv got a complete smallport motor and loom just missing ecu, so to put into a ae82 is just swap looms ? and get a smallport ecu
I have a smallport, loom, & ecu... The problem is that the looms can't be just swapped.
red car
Manfield - 1:24s
pc
Postby pc » Mon Feb 11, 2008 1:12 pm
Found some generic info on this thread.
http://www.toyotanation.com/forum/showt ... hp?t=88543
red car
Manfield - 1:24s
pc
Postby ChaosAD » Wed Feb 13, 2008 10:35 pm
or use th bluetop electrics and an aftermarket ecu :D
ChaosAD
Postby ~SlideWays~ » Fri Feb 15, 2008 11:17 am
Hey Pete i found a couple of links on this site, might be useful.
http://toymods.net/forums/showthread.php?t=5698
~SlideWays~
Postby pc » Fri Feb 15, 2008 1:22 pm
~SlideWays~ wrote:Hey Pete i found a couple of links on this site, might be useful.
Lots of good stuff there, ta
I think I need a spare AE82 manual loom now to start the wiring :)
red car
Manfield - 1:24s
pc
