not_paul_from_waiheke wrote:99% it is the right output. it is an old lemv5, using a laptop to tune. have tried testing with a multimeter but couldnt get any results.
piw wrote:That's a b**tard of a problem and occours only on the G3 series ECU's.
The problem is that with no power on the ign to the ECU, the ECU brain is not working as it's turned off and does not know to turn the internal transistor off.
PITA,
as I found out after I had wired most of the car that weird things happen,
in my case when you turned the ign off the whole car kept running,
lol.
To fix it,
Every input that goes to the ECU, must come from a switched ign source,
so you ned to change the battery feed to the FP relay, to and ign feed,
only on the relay winding side, not the main Bat side.
lol.
To fix it,
IH8TEC wrote:
there were two wires left over from the standard relay
big black and white wire - only had +ve 12v in the start position
little white and black wire - think it's an earth, but didn't need it.
