Running rough
Running rough
Postby tsoob » Mon Feb 11, 2008 9:17 pm
Last night i started me car to drive home from around the corner and it was running really rought rich as spitting out fuel smoke and misssing, i started this morning and it was the same. I put new plugs in and have checked the compression, it is ok it has been driving around for about 6 weeks on the 4agze base map supplied by microtech with no problems until now.
Does any one have any idea what is wrong with it?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Crucible » Mon Feb 11, 2008 9:50 pm
black smoke? plugs sooty?
check you're fuel pressure for starters, if thats ok then it can only be the injector Pulse Width at fault.
wide open maybe?
Crucible
Real Life Mechanic
Postby Alex B » Mon Feb 11, 2008 10:19 pm
What do the plugs look like? Any ones different to the rest?
Postby tsoob » Tue Feb 12, 2008 9:25 pm
i had a mate look at it and the water map was all over the show have fixed it but is still quite rough when it comes on boost it misses a bit and has flat spots. It feels like the turbo is fully spooled but the injection isint right for the boost level any thoughts
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Lloyd » Wed Feb 13, 2008 7:24 am
Water map?
Why are you still driving around on a base map?
Postby tsoob » Wed Feb 13, 2008 10:41 am
its going on a dyno next week i organised it this morning.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
