NZVengeance wrote:if this is stupid tell me.... nicely
NZVengeance wrote:huffer?
Trls250s wrote:Jun have taken 20v heads an put them on a 1UZ
Trls250s wrote:Jun have taken 20v heads an put them on a 1UZ so anything is achivable, but the amount of modification and etc needed to get it there was up in the thousands.
barryogen wrote:If you have a 3sgte, the better head would probably be the dual vvti one from the Altezza, but I'm not sure it is compatible, some reading on it suggests that some of the required oil galleries are not there on the previous generation blocks.
sergei wrote:Why do you think that 20v head flows better than gen3 3SGTE head?
It does make ~200Hp in NA form (with assistance of fancy manifold and VVT), which is better power per litre than 20v (because it actually makes that power unlike ~140Hp of ST or ~155Hp BT).
