How to take window out of door
Postby gleem » Thu Feb 28, 2008 1:00 pm
Hi all how do you take the glass out of the drivers door, the window is fully up, ive un done the two bolts which appears to be holding the window and it won't budge anyone got any tips?
gleem
Postby Distrb » Thu Feb 28, 2008 2:09 pm
once you've undone the bolts, wind the window down to the bottom and wiggle the glass out of its runners, and you should be able to remove it from there
Distrb
Regular Poster
Postby gleem » Thu Feb 28, 2008 2:14 pm
its an electric door is there anyway of winding it down without having to hook it back up
gleem
Postby Akane » Thu Feb 28, 2008 2:15 pm
Supply 12v to the motor, there should be a plug which connects the motor to the switches.
Undo that plug and just give it 12v of love.
Would check to see continuity to be sure which one is earth / ground tho :)
Postby gleem » Thu Feb 28, 2008 2:48 pm
ok so your saying just hook the window motor up to a 12v battery and u can wind it down that way
gleem
Postby Akane » Thu Feb 28, 2008 5:43 pm
yes, I did it once on my co-worker's Isuzu coz his switch died
And once on my MR2 when I needed to swap the doors over, keeping the same lock cylinder.
Postby sergei » Thu Feb 28, 2008 6:36 pm
there is no ground on motor terminals, it flips the polarity for either up or down, just apply 12v to the pins and if it goes wrong way, flip the polarity.
