fitting boost gauge to 99 st215w help
Postby HamzGTT » Sun Nov 11, 2007 4:35 pm
Ive just brought a Prosport boost gauge and need help as to where the best place to t in under the bonnet I know there has been another listing in here some where but cant find it. Am wondering if its best to t in to the factory BOV line or is there a better place.
HamzGTT
Postby 99gtt » Sun Nov 11, 2007 6:58 pm
T it off the throttle body line , you cant miss it .
SOON TO BE 500 HP
99gtt
Postby sleepy » Sun Nov 11, 2007 11:26 pm
On the same topic, is there any hole on the drivers side of the caldina where I can poke the vaccum hose into the cabin? I can only see a gormet on the passenger side and that looks like I am gonna be needing a loooooooooong vaccum hose if I was to mount the guage on the drivers side near the pillar.
sleepy
Postby GTTpower » Mon Nov 12, 2007 8:19 am
Yes you will probably have to run the long way.
I tried going through the steering column but too hard
GTTpower
Postby sleepy » Mon Nov 12, 2007 11:22 am
GTTpower wrote:Yes you will probably have to run the long way.
Man that sux balls -_-
Anyway cheers for that.
sleepy
Postby AJz » Mon Nov 12, 2007 2:17 pm
i ended up running the hose through the passenger side loom grommet, but my boost gauge sits under the stereo so i didnt have to go as far.
I had vtax :(
AJz
Postby touge rolla » Mon Nov 12, 2007 3:19 pm
feed it behind the drivers side front fender, then have it go into your cabin with the wiring from the door. easy.
touge rolla
boost gauge
Postby thedrunkfish » Fri Feb 29, 2008 11:43 am
ive just brought a boost gauge myself, was there a 12v wire spare back there for hooking it up?
thedrunkfish
Postby darkwolf » Fri Feb 29, 2008 3:07 pm
DONT remove one of the air vents and put it in there, condensation WILL eat your CDs.
A friend of mine has done it and on long trips it becomes really annoying. Especially in summer. Hot + music or cool + no music.
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Re: boost gauge
Postby AJz » Fri Feb 29, 2008 7:19 pm
thedrunkfish wrote:ive just brought a boost gauge myself, was there a 12v wire spare back there for hooking it up?
where exactly do you plan to put it ??
I had vtax :(
AJz
Postby thedrunkfish » Fri Feb 29, 2008 8:26 pm
aboce the steering wheel mate
thedrunkfish
