Is a Flexi definitely needed for a fwd plumb-back WG?
Postby ~SlideWays~ » Mon Mar 03, 2008 3:23 pm
Wanting to plumb my external into the Down Pipe but finding it hard to source a short 38mm flexi.
Is it a neccessity to have a flexi in the return pipe? Does it depend on the design/length/thickness of piping?
Otherwise, does anybody know of a supplier of SHORT 38mm flexi's? Have only found 200mm which is way too long.
Thanks.
~SlideWays~
Postby IH8TEC » Mon Mar 03, 2008 4:41 pm
YES
it'll crack, then you re-weld, and will crack again and so on and so fourth if you don't.
Postby flygt4 » Mon Mar 03, 2008 5:11 pm
i saw some on trademe the other day actually.
had been wondering this myself as about to plumb back in.
flygt4
Postby QikStarlie » Mon Mar 03, 2008 5:23 pm
stock exhaust off gt starlet, have nice short ones, that are the correct diameter as well. may not look so pretty tho
QikStarlie
Postby loose_unit » Mon Mar 03, 2008 5:45 pm
I got mine off a ee90 corolla. No not pretty but it was free, and right diameter.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby evil_si » Mon Mar 03, 2008 5:56 pm
i get mine from chase exhaust components in penrose,
not sure if they have 38mm ones thou, and they usually have short ones as well.
evil_si
Postby loose_unit » Mon Mar 03, 2008 6:09 pm
I would have used a short one but price put me off, would definately look alot tidier.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby ChaosAD » Mon Mar 03, 2008 7:43 pm
ChaosAD
Postby ~SlideWays~ » Mon Mar 03, 2008 8:06 pm
Cheers guys and thanks for the link but I've already seen those.
As I said 200mm is too long unfortunetly.
~SlideWays~
Postby tsoob » Mon Mar 03, 2008 8:36 pm
ill post you a pic of how we did mine tomorrow there it comes quite short like a bov straigt into the dump pipe, very effiecient use of space
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby gleem » Mon Mar 03, 2008 8:50 pm
just vent to atmosphere au
gleem
Postby IH8TEC » Mon Mar 03, 2008 8:53 pm
gleem wrote:just vent to atmosphere au
flyer got sent aroudn to warrant places showign them a picture of a external venting to atmo, saying that is illegal,
the fact that they showed pictures on it clarified them and cleared any doubts, so technically you should not be passed anymore.
Postby ~SlideWays~ » Mon Mar 03, 2008 9:48 pm
tsoob wrote:ill post you a pic of how we did mine tomorrow there it comes quite short like a bov straigt into the dump pipe, very effiecient use of space
Sounds good cheers
~SlideWays~
Postby gasman » Mon Mar 03, 2008 10:04 pm
i was thinking of getting something like this for when i eventually have to plumb mine back up but just using a few of the ribs
"What can possibly go wrong?"
gasman
Postby IH8TEC » Mon Mar 03, 2008 10:18 pm
Postby tsoob » Tue Mar 04, 2008 4:53 pm
Here is the way we have mine setup
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Tue Mar 04, 2008 4:56 pm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby MR2SIK » Tue Mar 04, 2008 5:04 pm
So do they fail on the noise issue or the fact that the exhaust exits in front of the passenger compartment?
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby crispy'86 » Tue Mar 04, 2008 5:28 pm
the fact that the external wastegate pipe is classed as part of the exhaust system and should therefore be plumbed into the exhaust system.
crispy'86
Postby IH8TEC » Tue Mar 04, 2008 5:37 pm
nah it's the forward of the passenger compartment
